How slow is too slow?
  • 80sailor
    • Feb 2014
    • 98
    I believe my 88 to be underperforming in the speed department.
    It has a 2.25 petrol Turner remanufactured engine that's got about 20k on it. Zenith carb and overdrive, too. On a flat highway the best I can do is just about 60mph. Hit a hill and I'm down to 50ish. Downhill with a tailwind I'm good for 65 or so. It's concerning enough that it makes me very Leary of getting on the highway with cars doing 70+ coming up behind me.
    I'm wondering if the carb could be holding me back. Either there's a problem with it or it's dirty or something. The truck seems to run fine. Decent idle speed but with just a bit of up and down, but doesn't stall or cut off.
    I've also noticed that my fuel pump leaks a bit, but I have a hard time believing that's the issue. The engine just seems to run out of air/gas at higher speeds.
    Would love peoples thoughts on where to start to remedy this. I don't intend to do an engine swap. Would consider a new carb (Webber?) for sure. Maybe even a new head /cam if it really made sense.
    thanks for the help.
  • NickDawson
    • Apr 2009
    • 707
    I have the rare 2.5L petrol engine and am hard pressed to do more than 65. Although I'm not sure if the engine is limiting me, or the pucker factor. Frankly, the idea of doing 60 mph in a piece of aluminum foil without a roof, or roll cage, and with a steel steering column inches from my chest scares the heck out of me.
    • flighht2k5
      • 17
      In my Unimog I usually cruise 45 to 50. I put a triangle on the back and just cruise in the right lane.
      Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.
      Benjamin Franklin
      • stomper
        • 889
        That sounds about right for 2.25 performance. With a few adjustments and a tune-up, you may get another 5mph out of your flat top speed, but aside from that, this is what you signed up for by buying an old Land Rover.
        Stay in the right lane on the highway, and let them pull out to pass you. The phrase "slow down and smell the roses" always comes to mind when I drive the rover after a modern car for a while.
        • darbsclt
          • Jul 2013
          • 162
          With the caveat that I am fairly new to series vehicles... I'll run down the list of "improvements" that my PO completed. They seem to be pretty standard in the "How to get the most out of your 2.25 petrol engine handbook"...
          - Rochester Carb
          - 9:1 comp head
          - 2.5L Cam
          - K&N Air Filter
          Since these were all completed by the time I found "Gracie"... I have no basis of comparison against previous performance.
          What I have added & plan on adding...
          Completed...
          - Pertronix Electric ignition (it might be my imagination, but the engine seems smoother/peppier)
          This Week...
          - Swapping out my 15" wheels/tires (29"dia) for 16" wheels/tires (32"dia) - with ~10" extra travel/rotation the engine will hopefully top out at a slightly higher speed.
          (note: 16" wheels were optional for NADA 88's & my speedo was originally calibrated for 16's)
          Future (when needed)...
          - Swap out my existing exhaust system for a larger diameter, less restrictive system.
          (note: I believe that I read this on a post from TerriAnn, who has a great summary of engine modifications on her site... http://www.expeditionlandrover.info/...onversions.htm)
          Good Luck & Have fun tinkering!
          • stomper
            • 889
            Just a quick thought I had last night. Do you have free wheel hubs on the front of your truck? Keeping them unlocked while on the highway seems to add about 5mph to your top end speed also. Don't know if this is part of your dilemma.
            • bugeye88
              • Apr 2013
              • 167
              I agree with darbsclt on upgrades for a bit more power. Most of it boils down to get air in and get exhaust out. The carbs of choice for me have been Rochester (properly jetted and tuned for your altitude) or the Weber 34 ICH, K+N filter, 8:1 or 9:1 head, 2.5 cam (I need to do that), fix that fuel pump and add a in line switchable electric after the manual pump, tune the hell out of it. Prepare for mind numbing acceleration.
              • Revtor
                • Apr 2012
                • 265
                Ive got a 2.25, 7:1, Zenith, 235/75/16 (29") tires. I can hit 60 on the highway, with the OD engaged. Pretty much max. (That I want to rev it at least) Id say you're doing fine, 2.25 wise.
                That speed is more than enough for highway travel. Get out there and cruise! 55 stay alive, let everyone else cruise by and stare.
                ~Steve
                ---- 1969 Bugeye ----
                ---- 1962 Dormobile ----
                • bugeye88
                  • Apr 2013
                  • 167
                  Right on Revtor!
                  • 80sailor
                    • Feb 2014
                    • 98
                    Ok, I just wanted to make sure I wasn't crazy. I know I signed up for slow and noisy. Just wanted to make sure I was getting my money's worth.
                    Thanks all.
                    • LaneRover
                      • 1743
                      69 109 p-up with an overdrive, military re-built 2.25 16" rims and a rochester and I easily cruise at 65 on the highway and 70 wasn't unheard of.
                      • bugeye88
                        • Apr 2013
                        • 167
                        Hills are another thing though....
                        Rob
                        Bugeye88
                        • LaneRover
                          • 1743
                          Rob
                          Bugeye88
                          Yes . . . yes they are . . . depends on the hill of course.
                          Florida hills? Not much problem!
                          Colorado 'hills' I got down to about 30mph
                          • bugeye88
                            • Apr 2013
                            • 167
                            Yep. I live at 7200 ft. and occasionally travel to Salt Lake which is 4200 ft. Going down is harrowing but I keep it down to 60-65. Going up I can go 40-45... 50 with a tail wind, with the Bugeye in 3rd overdrive. Not too bad. The engine is a 2.5 with 8:1 head, 34 ICT Weber, K+N and good tune. On the Flats.... mind numbing acceleration......
                            Rob
                            68 Bug Eye 88 Nellie Belle
                            • TeriAnn
                              • 1087
                              The best way to check to see if you are getting your money's worth is to have someone press the accelerator pedal to the floor and hold it there (engine off) while you check to see if the linkage has opened the throttle all the way. Also if your timing is not advanced enough you will not be getting all the power you paid for. Either way a caution, slow moving vehicle sign is not out of order.
                              I had your power problem for the first 21 years I drove my truck. I solved it with a Ford 5.0. I now have more power at idle that the 2.25 had at peak and with some higher gearing have no problem keeping up with traffic in a 75 MPH zone. Oh, and I ended up with better fuel mileage
