How identify my LR Series transmission or gearbox
  • amonaliberty
    • Jun 2008
    • 18
    Hola everyone!!
    I need a little help identifying the gearbox that have my old LR Series III 88"(1972) 2.25 petrol. It is because I think the first owner change it. I need clues on how to identify its or difference from the ones of the LRS II, like serial numbers plate or where it is, how look in the exterior the ones from II or are alike looking, are the same exterior body? or if can publish photo that I can use like a guide when look mine. I know about the change in mechanic and synchro in the shift. If anyone can give me a clue, I will really aprecciate a lot and Gracias!!
    Ed Cintron
    Facebook/Land Rover Series Puerto Rico
  • Revtor
    • Apr 2012
    • 265
    Ed, I think if you took a few good pictures, there would be someone who could ID the transmission for you. The best way would be to find the stamped (not cast) serial# and post that. Im not sure what external changes were made.. They would probably be minor at best..
    a few good links regarding serial #'s
    My eyes have gone square googling and reading info on identifying series gearboxs. This info comes from quite a few sources. Please tell me if there is an error. There are 3 types of gearbox: Series I
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
    • stomper
      • 889
      The clutch slave set-up is different from the IIa to the III transmissions. see if you can get a picture of that.
      • Partsman
        • May 2011
        • 329
        And if you can't get an answer here, try the Series 2 Club forum in the UK, there are many there that can narrow down the year of manufacture based on your numbers, give them your chassis number and the number of your tramsmission, and they can tell you the likelihood of it being the one it came from the factory with.
        Series 2 Club Forum
        Andy The Landy Shop
        • Cutter
          • Feb 2009
          • 455
          If it is a series III, the serial and suffix are on the top of the transfer case housing where the casing connects to the transmission.
          • amonaliberty
            • Jun 2008
            • 18
            ~Steve
            Thanks Everyone!!, during the week-end I will take some photos and publish its. I know for sure that the clutch slave is in the driver side(LHD) and when I shift first to second, i have to decrease speed or double clutch. And when i low from 3rd to 2nd it sound a little and have to decelerate.
            Ed
            • stomper
              • 889
              I series IIa clutch slave should be on the passenger side, and is mounted vertically. I believe the series III setup is on the drivers side and is mounted horizontally. Someone with a series III might chime in. I don't think you can use a series III clutch mechanism with a series IIa transmission, but someone should verify this for me.
              • amonaliberty
                • Jun 2008
                • 18
                Thanks !!, I will take photos during the week end and publish its.
                Ed
                • Cutter
                  • Feb 2009
                  • 455
                  Yes regarding SIII clutch horizontal on LH Side
