Hello everyone -
Have a some questions in regard to the rear hubs.
I'm refurbishing all four of them and have started the reassembly and as usual questions come up.
#1 - The shop manual says to smear the outside of the oil seal with "joining compound". What is joining compound? I've used grease on other seals elsewhere.
#2 - The shop manual also says "DO NOT press seal below the rear face of the hub..." Okay - I guess this just means to make sure it's level with the edge - this is what I've done. The bearing now moves up and down since the oil seal is not pressing it down. If this is the case I'm assuming the distance piece presses the bearing in place and THAT'S why the face of the distance piece must be smooth. Is this correct?
I've attached pictures so you can see what I'm talking about. In the pic of the seal you can see the gap between the seal and the bearing.
