Turn Signal Switch
  • bensdad
    • Mar 2014
    • 77
    Turn Signal Switch
    Okay, my '60 Series 2 has what appears to be a vacuum type turn signal switch, but I can't find out anything about it. I don't see it on our hosts website either.
    It also has a green (I think) light that goes above it on the panel. Was this original and how does it work? Does anyone have any schematics or pictures I could check out? Thanks as always!
  • stomper
    • Apr 2007
    • 889
    Definitely not original. You should have a Tex Magna turn signal on the colum for originality.
    • bensdad
      • Mar 2014
      • 77
      Searching the web it seems that I have a pneumatic type turn signal switch. Prob from an MGA or Jag. Hmmmm...
      • CMorris
        • Jan 2007
        • 66
        You have the proper switch for a Series 2.........there's a plunger inside the switch body that needs to be oil soaked to create a vacuum which is adjusted by way of a small screw on the back of the unit. They are very hard to find so hold onto it or sell it to me! Check with our hosts about some sort of schematic on the switch, they must have something kicking around.
        • leafsprung
          • 1008
          Colby is right - its original for SII I have the wiring diagram
          • bensdad
            • Mar 2014
            • 77
            Well that is cool thank you. I am going to go through it and see if it is working properly. I like the concept. Thx gang.
            • TedW
              • 887
              bensdad: Please post a photo of this switch! I also thought the Tex Magnalite was stock for Series IIs, so it's good to know the truth.
              Ted
              • leafsprung
                • 1008
                The tex switch is stock for SIIA so late 61-72.
                Ted
                • darbsclt
                  • Jul 2013
                  • 166
                  Love learning new things! This thread prompted me to take a second look at the parts catalogs & sure enough, I'm guessing this is your switch (# 3).
                  • bensdad
                    • Mar 2014
                    • 77
                    Yes, number 3 is the switch and 13,14 and 15 are the dash light cnd crystal. I can't figure out how the dash light attaches to the dash plate, but am working on it. I don't have the steering column mounted turn signal. Will take a picture of it if I can get it all put together.
                    • ignotus
                      • Sep 2009
                      • 237
                      Those are still available new in the UK.
                      gene
                      1960 "bitsa" 88--Ignotus
                      1960 109, 200TDI
                      • bensdad
                        • Mar 2014
                        • 77
                        Using your part number Lucas identifies is as a Pnuematic Timer Switch. it works on air pressure. Hoping I can get it to work. Thanks for the help guys.
                        • darbsclt
                          • Jul 2013
                          • 166
                          If you haven't already stumbled across them... here are a few forum threads that might be useful...
                          Jag Lovers Web
                          Series 2 Club (see reply #8)
                          Series 2 Club (entire thread)
                          Hopefully you'll be able to mend it (I love seeing old bits refurbished).
                          Good luck!
