Front and Rear Differential Pumpkin
  • jp-
    • 981
    Are the front and rear differential pumpkins (chunks) interchangeable?
    I think they are, but just wanted a second opinion.
    67 IIA 109" NADA Wagon (sold)
  • scott
    • 1226
    yep they are. i even got a rrc 3rd member onto my iia w/ a little mod.
    '64 Series IIA 88 Canvas Tilt
    '68 Series IIA RHD Ambulance
    '76 Spitfire 1500
    • daveb
      • 513
      yes, with the caveat that some front diffs don't have a fill plug and thus will not work in a rear application.
      rgrds
      dave
      • scott
        • 1226
        yea, neither front or rear rrc's have fill plugs on the 3rd mbr, they're on the diff covers. i solved that problem by jacking up the right rear side, removed the hub and axle and poured the spec amount in. i still have to do it that way even after put a iia 3rd mbr back on, the fill plug is a bit rounded off.
        '76 Spitfire 1500
