I'm getting ready to install RN door seals this weekend on a newly installed soft-top/hoop set/gutters (Series 2a 88). Should the top door seals be trimmed at 45 degrees in the corners or let it run straight across (as it is out of the RN box)? If someone could upload a close-up photo or two that would be great.
If I cut the top door seal then the side/back door seal will need to be cut as well.
Just checking - Ask twice, cut once
