Waxoyl (and similar) into Bulkhead Pillars on Series IIa
  • warrenperkinson
    • Jan 2014
    • 78
    I'd like to get some decent rust protection inside the bulkhead pillars of my series IIa 88" (I use a product similar to Waxoyl called Prolan - which is a lanolin based product which I highly recommend).
    I have thought about injecting it through the hinge mounting bolt holes, but I have also read on other sites about drilling a small hole into the top of the bulkhead pillar.
    Has anyone tried either of these on a series IIa? Which would you recommend? Or is there a trick that I'm missing?
    Cheers...
    '71 Series IIa "Horace"
    88", RHD, 2.25 petrol.
    New Zealand.
  • TedW
    • 887
    Cheers...
    You can get very good access through the hinge holes; especially helpful is one of the plastic hoses with the 360 degree applicator nozzle, available from our hosts. That guy can get you just about everywhere in the bulkhead - and the frame, as well.
    • o2batsea
      • 1199
      Or take off the wing and shoot thru the spire nut holes
