I posted a few weeks back about putting a 69 2A 109 ex mod regular on a 2A wagon frame. I think I've sorted what needs changing to make that happen. My next question is I've found a potential frame but it's an early 2A. are there any major things I may be overlooking with that swap? I know the hand brake bracket, catch strap bracket are different. Anything else that will be a deal breaker?
Going from a later D 2A frame to an early A-C frame
If you own a simple, economical little 110v MIG welder and a 4 1/2" grinder with a cutoff wheel, then I susspect there's no such thing as a deal breaker, unless the chassis you have in mind is galvanized.--Mark
