I was finally able to climb under the IIA and found the source of our loud clanking sound when we are starting to pull away. It seems the sound is from the front drive shaft / universal connection. Where the shafts slide together under the boot. That is where all the slop is. Does this sound normal? Or would a new universal joint tighten this up?
I tried to separate the front end of the shaft at the 4 bolt coupling but they sure are snug. I'm afraid I am going to snap something. Would it be unwise to hit the nuts with some heat from a torch? Any tricks here to remove the whole shaft or is that over-kill.
Thanks...
jay
Thanks...
jay
