When I got my '65 IIa 88 I had a new fuse box and wiring harness installed. Yesterday I happen to take the cover off and I found that there was no fuse in place for the top line. There is a brown wire running into it that is hot (even when ignition switch is off) and a purple line running out on the other side (see pic below)
The guy that did the work was pretty knowledgeable and he seem to do things by the book so possibly the coloring of the wire might help to figure out where the purple line goes (I checked lights, blinkers, heating fan, back up lights, wipers and everything works?). Given that the line is live all the time I simply do not want to just put a fuse back in without knowing what will do (i.e., drain the battery, etc..).
As a side note I want to install a radio. Any ideas of where I can tap into a hot line when the ignition is on (i.e., lower line of the fuse box or tying into the line that goes to one of the wiper motors?), or should I just wire it to the battery and have a switch to give the unit juice.
Any insight on both either issue above would be greatly appreciated.
Mark
Mark
