I've been making decent progress on disassembling my '82 Series III 88" for a frame-over & refurbishment. Next on my list is removing the steering components, first of which is the ignition switch housing. The green bible says to use a centre punch to drive out the screws, but I'm not sure I quite follow. I assume that I shouldn't be trying drive it straight out, but instead trying to turn the head on the underside by using the centre punch at an angle, correct? Or should I be using a pin punch to drive it down from the top?
I'd like to keep the steering column & steering box mated & assembled for the time being, to limit mess until that stage of the rebuild. Plus, my Series III was originally a petrol, but was converted to diesel, so I'm highly considering swapping the ignition switch for a diesel version.
Thanks in advance for any tips.
