Blower Motor
  • rbbailey
    • Sep 2010
    • 161
    Blower Motor
    I did a quick search, so point me in the right direction if I'm missing something.
    I've got the original blower motor from the Kodiak in my '65 IIa. It always worked, but it was low power because... well, I guess the bearings are bad, or it's dirty, or whatever else could go wrong over 50 years of work.
    So, can I expect to get more life out of it if I pull it apart and clean and "restore" it myself, or should I just take it to a local pro and let them deal with it for $100 or so?
  • darbsclt
    • Jul 2013
    • 166
    These have been listed as replacement motors...
    NAPA M882 (this may be an old part number - I imagine they can cross reference it)
    Auto Zone - VDO PM351
    You may want to check them out first...
    • o2batsea
      • 1199
      Yah they're a pretty standard-issue 12V fan motor. Made in USA. Prolly prestolite or some such. You should be able to find a direct replacement for cheap.
      • rbbailey
        • Sep 2010
        • 161
        OK, that's good to know.
        I partially disassembled mine and cleaned it up. It seems to run pretty well. I may just put it back in and if I have to replace it later, fine. As long as it appears to be an easy bit to find. Thanks.
