Rear Window wiper. Arm and Wiper Blade Replacement
  • clearcut
    • Jul 2014
    • 233
    Need to replace asap the Blade.
    It is 12 to 13 inches long
    It attaches by the screw in the picture
    The blade can come out of the arm holder
    Any directions?
    thanks
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
  • o2batsea
    • 1199
    Could be early Anco
    • chuckstp
      • Oct 2014
      • 82
      I was able to take an off the shelf blade and extract the rubber to replace the front ones. With the size of it, I cut both from one blade. If the design is similar to the one I have, you can slide the retainer clip at the end forward and pull out the metal runner.
      • clearcut
        • Jul 2014
        • 233
        HI
        I took your idea!
        Trico Wiper Blade Refill, 45-200 is the correct size
        The store manager had to go into storage area in back to find it.
        Bought enough to make two more
        thanks
        josh
        1967 Land Rover 109
        1966 Land Rover 109
        Joshua Tyler
