I attempted to locate the timing marks on my '64 IIA. I'm not really sure how anyone can see them at all with the engine in the vehicle, but with the floorboard out to bleed the clutch line, I removed the cover and mounted a camera so I could look at the flywheel. All of the drawings in the manual show the TDC with an associated mark along with 3 and 6 degree markings. I found a marking which is presumably TDC labeled with an 'E' and a 'P' on either side of the mark and nothing else.
Has anyone else seen anything like this? Should I simply count the teeth to determine the degree of offset when setting the distributor?
