VEHICLE:
Daily Driver: 1971, S2a, 88, LHD, 2.25 petrol, Soft-top
Note: I've also inquired about these thread specs directly to the RoamerDrive guys, but I think that they're trying to take a few days off during the holidays. (The thread specs referenced below relate directly to the installation of the RoamerDrive SS unit.)
PROBLEM:
Went to install my new RoamerDrive SS and encountered a SERIOUSLY FROZEN "castle nut" on the transfer case gear shaft. (This castle nut holds the one gear that needs to be removed in order to install he RoamerDrive SS coupling, and then the complete overdrive housing can be installed onto the back of the T-Case. Sounds quick and easy, right?)
With the help of a friend with an acetylene torch, we finally got the carefully heated (R.H thread) castle nut to come off the shaft. (I'm guessing that the PO must have, for some reason, went crazy on the nut in the past, but we can't be sure. The nut is supposed to be just somewhat "snug" up against the gear.) But now, after finally removing the castle nut, the first two or three threads on the gear shaft are distressed - just enough to where I don't dare try to install the SS coupling on the shaft now, and end up forcing the brand new hex nut onto the shaft to secure the coupling, ending up damaging my new hex nut too!
Does anyone know the thread specs of the transfer case shaft in question? If not, I'm sure the RoamerDrive guys will get back to me soon.
And... I'm going to visit my local machine shop today and hand them the "RoamerDrive HEX NUT" that is extremely anxious to be installed onto the shaft, and maybe they can determine (using their closest sized tap?) what thread die I should utilize. Of course, I prefer to procure the Genuine Specs, and then order the Correct Die for the job. (What a wild and crazy idea!?)
If you have any info, I would appreciate hearing from you...otherwise, I'll try to maintain myself, and continue driving my old Dodge truck to work...BORING!
Thanks!
Dave
(A shade tree mechanic who doesn't even have a shade tree.)
PROBLEM:
Thanks!
Dave
