I am replacing the brake master cylinder and when I removed the reservoir noticed a black gasket that had mostly disintegrated which had been between the main reservoir and the internal tube feeding the clutch system. This is for a 64' SWB with a CB type master if that makes any difference. I hadn't found any mention of a gasket and very little mention of the internal clutch cylinder.
My question is, what should I use to seal this in order to prevent leakage without compromising the break fluid in the process?
