1967 Series 2A 109 NADA 2.6L Engine in final stages of rebuild in machine shop-they have limited experience with Rover engines but all that was available locally. The shop is having trouble with lining up the harmonic balancer timing marks to the timing pointer. They followed the instructions to rebuild the engine in the 2.6 cylinder overhaul manual and physically located the camshaft chain wheel as directed and they mechanically have components timed and turning by hand with the engine #1 piston at TDC with the crankshaft key pointing straight up to 12 oclock. With the balancer mounted with key at 12 oclcok and piston 1 at TDC timing markers (TDC, 2 and 6) are no where near the pointer. To describe the locations-with the balancer mounted on the key at the 12 oclock, the timing marks are located at the 2 oclock position and the timing pointer is at the 10 oclock position where there is no mark. On the rear side of the balancer edge nearby the timing pointer is the E P marking but it is not on the timing pointer either. Machine shop is wondering if the inner pulley may have shifted from the balancer or if they did something incorrect in the install.
I f my description leaves something out-please ask. I am not an engine mechanic and have attempted to describe what was shown to me.
Any help is appreciated! If the machine shop can speak to someone who knows what we are doing wrong even better.
Ed
Ed
