8 spoke width
  • LRover74
    • Sep 2010
    • 41
    8 spoke width
    Does anyone know the width of the white aftermarket steel 8 spoke wheel? It has 265/85/16 but will lime to put 235 /85/16 . My searches show it to be 7" but it measures 8"
    • 390
    The ones I had were 7", as measured from bead seat to bead seat.
    • LRover74
      • Sep 2010
      • 41
      Thanks ,you are correct,they are7". I measured wrong. Do you know if 235/85/16 will mount.
        • 390
        Most 235-85-16 tire specs recommend a 6" to 7" rim width, but you should check the specs for the specific tire you intend to use. The rims I had offset the tire a bit more outboard than normal, but there are several different factory offsets on Series rims.
