Need Help Brake fluid What level should this be?
  • clearcut
    • Jul 2014
    • 233
    Thanks
    Josh
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
    Full?
    • bugeye88
      • Apr 2013
      • 167
      ClearCut,
      Level looks OK, fluid a bit gunky, Probably flush the fluid through, but if it doesn't leak big time you are OK.
      Rob
      Bug Eye 88
      • darbsclt
        • Jul 2013
        • 166
        ^^^ Yes ^^^
        Flushing/bleeding the clutch/brake fluid should on your annual maintenance check list.
        • clearcut
          • Jul 2014
          • 233
          HI All
          I added the brake fluid. No more brake fad
          Drove the Rover back from Sacramento to Santa Cruz.. About 160 miles
          45 mph over highway 17
          No brake fad on the down hill into SC
          All Rovers mark there spots.
          About two week ago, the Rover started to spot on my pans, coming from E-Brake area(Very dark) Not like gear lub. The break fad started after that started.
          Drove the Rover for a surf check this am, brake fad again. Around town you due use the gears a lot.
          The spot is in the middle of the truck
          I have no leaks coming the the brake drums
          What could it be, and where would you look?
          I due plan on replacing the fluid next week
          thanks
          josh
          1967 Land Rover 109
          1966 Land Rover 109
          Joshua Tyler
            I'd be looking for a pinhole in the metal brake line that goes down the chassis rail to the rear brakes.
            Fill up the brake reservoir, have someone step on the brakes while you look for brake fluid squirting out of the line toward the transmission brake area if you say that's where you're finding a new fluid leak that corresponded to the brake issue.
