Cheers, what are the options for crash protection on a series front (or Rear) differential?
diff. protection.
To expand on that, what he is saying is remove the differential, cut the front bulge off the housing and weld a rounded end of a sewer cap in place for the cut off rounded bulge. This is popular with serious rock crawler rigs.
If you had a Salisbury in back there are a lot of bolt on diff protector options available. Any diff protector for a Dana 60 will work.
If you have a newer style pumpkin holding your differential carrier that has 2 holes in a flat section on the bottom of the pumpkin you can use our host's new diff guard.
There is a clamp on diff guard the has been common for LRs for years that has a band that goes around the housing and you tighten the band to hold the protector in place. These always fell off on me because I could never get it clamped tight enough to stay on in rough trails. Probably best to weld these in place.-
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
