Dear Rover Engineers
  • slowmo
    • Dec 2014
    • 225
    #16
    Dear Rover Engineers,
    I can't believe I have to write you again so soon, for since December I have replaced all the wheel bearings, all the brakes and wheel cylinders, the shocks, the exhaust manifold, the generator, the battery, the tires, the transmission, the clutch, slave cylinder and pressure plate. This is not all your fault, mind you. The previous owner didn't do any maintenance at all.
    I thought I might actually get to drive it. But no. A week later the rear axle broke, and now the master clutch cylinder will not pump up at all. I think I tore my hamstring pumping the clutch pedal so fast that my leg was a blur. I couldn't stop and I actually took flight and buzzed around the interior of the truck until I smashed into the fire extinguisher. The medical bill is in the mail.
    So here is my complaint. Are you serious? I have to remove the fender "er...wing" to yank the cylinder and put a kit on it. Really? Well that, sirs, is a design feature that is unique to Rovers, and cars made in Kazakhstan. Since they don't make cars in Kazakhstan I suppose we can call it a "Uniquely Rover design feature."
    Thank you, Rover Engineers. Job well done is not what I would say about the clutch master cylinder wing removal required debacle.
    --David
    1959 TR3
    1970 Series IIa 88" ("Homer")
    My hovercraft is full of eels.
    • bensdad
      • Mar 2014
      • 77
      #17
      OMG it all sounds so exhausting. I just put a new clutch master in w/o having to remove the fender/wing whatever on my 60. Of course you have to remove almost everything else in the world, but it did come out. This is a S2 btw. Good luck!
      • slowmo
        • Dec 2014
        • 225
        #18
        At least the fender (I mean...wing) is easy to remove. But why oh why. You could have designed the master cylinder and pedal assembly to be removed from inside the truck rather than having to remove the fender.
        I have a feeling we will be in contact soon. Both front swivel ball assemblies leak, but for cryin' out loud. Can't you let me drive it for a month or so?
        --David
        1959 TR3
