Cold Start indicator
  • slowmo
    • Dec 2014
    • 225
    I don't have the manual in front of me, but my cold start indicator is on all the time. What is this even for and is the indicator triggered? I am going to tackle gauges and indicators one after the other since none of them actually seem to function.
    Thanks.
    --David
    1959 TR3
    1970 Series IIa 88" ("Homer")
    My hovercraft is full of eels.
  • lumpydog
    • May 2014
    • 383
    Slo
    It's a simple switch. It's clamped onto your choke cable. When you pull out the choke, the switch button pops out (activates the light) as the choke arm/knob is pulled out. Slide the choke in and it obstructs/closes the button, turning the light off.
    This one should be simple - remove the 5 instrument panel screws and look for a small box clamped onto the choke cable immediately behind the instrument panel. It's probably loose or maybe slid out of place. The choke cable has three holes in it - two for bumps in the choke light switch box that keep it in place. One middle hole where the choke light switch button protrudes through - and toggles on/off with the slide of the cable.
    1968 Series IIa
    • slowmo
      • Dec 2014
      • 225
      Ah. I thought there was a sensor somewhere which gave the indication to use the choke and that the sensor was kaput. Instead, it is just a reminder that you are using the choke. Silly me.
      --David
      1959 TR3
      • siii8873
        • 1013
        some systems also have a temp switch at front of the engine near Tstat housing. You pull the choke cable which closes the switch discussed above. This switch is in series with the temp switch. So when you have the choke on and the engine reaches a set temp the choke (cold start) light comes on telling you that you have the choke pulled and the engine is warm.
        Probably a problem with the switch noted above it is staying on.
        THING 1 - 1973 88 SIII - SOLD
        THING 5 - 1958 109 PU
        THING 6 - 1954 86" HT
          Well, lumpydog's answer MAY be correct. Some engines had a simple system that merely went through the light switch then to ground as described by lumpydog, and some went through that same switch, enabling the light, then on to a temperature-activated switch (sometimes known as an "otter" switch) on the front of the engine, which illuminated the light by grounding the circuit once the engine is warm, reminding you to "turn off" the choke, so to speak...
          [EDIT:] Bob beat me to it--I spent too much time researching the name of the thermal switch.
          • lumpydog
            • May 2014
            • 383
            No otter switch on my engine. I wondered how that second temp sensor worked on trucks where I've seen it...
            So, if he has one, it sounds like a simple way for Slo to test if it's a faulty otter switch - Would be to see if the cold start light is coming on right away, before the engine is even warmed up. Pull out the choke, and turn the start key to the point where the dash lights come on - but don't start it... and see if the cold start light comes on. If it does, that would point to the otter switch because it's grounding the circuit without the engine being warm. Correct?
            But, even if it's a faulty otter switch, the the switch on the choke cable should be able to break the circuit if it's functioning properly...
            1968 Series IIa
            • slowmo
              • Dec 2014
              • 225
              I have a sensor which has obviously failed closed AND the switch is closed as well. I looked on our hosts site and didn't find the sensor. Anyone have a link so I can replace it? Thanks.
              --David
              1959 TR3
                They were used on other British cars. Jaguars and MG's come to mind. Google "otter switch" and do "images".
                • slowmo
                  • Dec 2014
                  • 225
                  The plot sickens...er...thickens. One of the PO's removed the switch completely. There is no switch. AND, when I disconnect the spade terminal on the otter switch, the light stays illuminated. So it is either shorted out somewhere, or connected to the wrong terminal. Well...at least this is not a mission critical glitch. Plan is to run new wires from the otter switch, the soon to be replaced water temperature sensor and the soon to be replaced oil pressure sensor.
                  I will then attempt to find the correct "otter" switch and attempt to find the bracket and switch assembly. Obviously this is not required and I could simply disconnect the light, but what the heck. I like everything tidy.
                  --David
                  1959 TR3
                  • lumpydog
                    • May 2014
                    • 383
                    Slo - Our host has the switch you need and I think Ike carries them as well - as mentioned, it's a small box that clamps onto the cable. Make sure your choke cable has the provision for the switch. It should have three small in-line holes on the solid stem that protrudes through the dash panel. If it's a later model S3 choke cable, it may have the switch attachment point on the cable itself, within the engine bay. If you need a choke cable that has the provision for the switch - Ike carries them (they are not entirely easy to find and I do not believe our host has them).
                    [Edit] Added picture (borrowed from Ike's site) to show the three holes needed for the switch.
                    1968 Series IIa
                    • slowmo
                      • Dec 2014
                      • 225
                      Thank Lumpy. Looking at the parts catalog it seemed there was a metal bracket which somehow held the switch on. Looking at the switch it seems to clamp directly on to the choke cable.
                      With the cost of the switch and an unknown cost for the correct otter switch I may utilize the warning light for my missile launching system instead.
                      --David
                      1959 TR3
                      • lumpydog
                        • May 2014
                        • 383
                        Yeah - I think Ike has one with the correct metal bracket that clamps/secures it in place… The RN one appears to clip on.
                        1968 Series IIa
                        • siii8873
                          • 1013
                          [QUOTE=slowmo;103983]Thank Lumpy. Looking at the parts catalog it seemed there was a metal bracket which somehow held the switch on. Looking at the switch it seems to clamp directly on to the choke cable.
                          the switch with the bracket is for earlier models, your vintage would have the switch on the cable as you note.
                          • mikeshaw247
                            • Aug 2018
                            • 5
                            Yep - I need this otter switch. I believe it is part number 545010 called a Thermostat Switch or Choke Light Switch. Different from the switch on the cable, which I removed. The switch on the cable tells you the opposite of what the Otter switch tells you. Otter switch says - hey - use your cold start. Switch on the cable says, hey, push in your cold start cable. Hard to find the otter switch. Rovers North doesn't seem to have it anymore.
                            Thanks!
                            Mike
                            • mikeshaw247
                              • Aug 2018
                              • 5
                              Otter Switch for Choke Light
                              Thanks!
                              Mike
                              I did find one. Yep - called Otter Switch, it seems everywhere. Now I just need to test mine to see if it's really broken.
                              Thanks all!
                              Mike
