Like many others on this forum I have been the victim of the dreaded vapour lock syndrome. So yesterday I decided to go the route of installing an electric fuel pump, bypassing the mechanical pump. I used a Carter P60504 pump with a fuel filer in-line between tank and pump and output from the pump direct to the carb (Zenith).
It started up and ran well but after a subsequent hot start it only ran for a couple of minutes before dying and I had to let it sit for about 15 minutes (bonnet up) before it would restart. I noticed that there seemed to be a fuel leak from the carb itself (not input line) as though it was getting too much gas. Once it restarted it seemed to run fine. That was its last run of the day.
I thought about installing a filter with a return line to the tank as has been suggested in other threads, but therein lies my problem and what I'm not sure about.
The fuel system (1972 Series III) is fitted with an emission control system for evaporative loss. This uses the connection on the top of the tank that I want to use the return line to. I thought about installing a T-piece so that I could connect both lines (existing one leading to the expansion tank and the new one from the filter return) to the tank.
If I do this would I need to put some kind of restrictor into the expansion tank line to prevent fuel from just being pumped into the expansion tank?
Also, would doing this prevent the main tank from venting properly? The fuel cap on the vehicle is not vented and the system relies on the expansion tank and charcoal filter for proper breathing?
See the attachment below for more details on the emission control setup.
Any thoughts? Has anyone already solved this problem when installing a fuel filter with a return line?
Thanks in advance for any feedback.
