Starter Solenoid on 63 IIa
  • timc930
    • Jul 2013
    • 117
    Is the starter solenoid part of the push button starter switch on the 63 LHD 88?
    tim
    Tim
    63 IIA 88" (Beach with the dogs)
    05 L322 (Daily)
    95 RRC SWB
    05 E320 (Wife)
    86 930 (Rush on boost, 400HP and climbing....)
    A few boring BMW's for the kids (E30, E36, E46, E53)
    No solenoid. Just a huge push-button switch sending full power to the starter motor (though if you wanted to incorporate a solenoid, what you described would be the way to do it).
    Have a look:
    • antichrist
      • Mar 2009
      • 272
      What Mark said.
      If you're asking because yours is dead you could go with something like this, if you don't care about originality. (the photos aren't to scale)
      and
      200amp continuous duty solenoid with silver contacts.
      Tom Rowe
      62 88 reg
      67 NADA x2
      95 D1 - R380
      95 D90 - R380
      97 D1 - ZF
      • timc930
        • Jul 2013
        • 117
        Thanks Mark/Tom...
        Starter is turning over very very slow, all connections are good, so I am getting ready to purchase and install one of these, and did not know if I needed to engage (use) or bypass the solenoid.
        Question on the switch, I assume the switch either works or it does not, and if the connections (power/ground) are good would either send all or none of the power to the starter. So if the starter is dragging, it should be a failing starter?
        ClassicCarPerformance.com, BritishBarnFinds.com, BritishStarters.com, BritishWireWheels.com, FerrariStarters.com, ItalianStarters.com, SideCurtain.com.
        tim
        Tim
        05 L322 (Daily)
        95 RRC SWB
        05 E320 (Wife)
          Yes, if the starter is doing SOMETHING when you press the button, then there is a connection being made. The question is: "is the connection adequate to carry the full electrical load?".
          Being lazy, I'd test the starter by chocking the wheels and putting the transmission in neutral with hand brake on. Then I'd connect one of my jumper cable leads to the input terminal of the starter, being careful that the lead makes contact with NOTHING else at any time, then I'd stand off to the side of the vehicle and touch the lead on the other end of the jumper cable to the correct terminal on the battery (positive terminal for a negative-earth rover or the negative terminal for a positive-earth vehicle).
          If the starter still turns over weakly, then either there is poor electrical connection somewhere in the path between the starter and the engine block and the battery, or the starter is dirty and needs to be cleaned, or the starter needs maintenance or replacement.
          If the starter runs like a scalded dog, then the problem is upstream of the starter (corroded battery terminals, connections or starting switch).
          NOTE: If the battery has been in a charging state immediately before you do this test, let the hydrogen gas dissipate before making any sparks around the battery terminal (like when you connect a jumper cable to the battery terminal).
          • timc930
            • Jul 2013
            • 117
            Could I disconnect the battery cable from the starter switch and touch to the starter side of the switch to bypass switch just to rule out switch? Obivously wearing gloves and fireproof suit....
            tim
            Tim
            05 L322 (Daily)
            95 RRC SWB
            05 E320 (Wife)
              tim
              Yes, though that won't isolate the starter and the electrical return path as the culprit as you could still have a faulty connection in the power supply path. Instead you will eliminate the switch only as a possible cause.
              Either way, I'd still make the final energizing connection at the battery and not any of the other terminals. This means disconnecting the battery end of the wire, pairing up the battery wire with the starter wire so they're on the same lug on the starter switch, then energizing the whole thing by touching the battery cable to the battery.
              The reason for this is that when you touch a hot wire to a terminal in a live, high-amp circuit like this, there is an arc, just like arc welding, and it tends to cause damage to whatever the arc briefly melts. Melting the lead terminal end of the battery wire is no problem. Knackering up the threads on the starter terminal posts is quite a bit less-desirable.
              You could always clamp one end of a jumper cable to the starter wire at the switch and touch the other end to the appropriate battery terminal. This will eliminate everything upstream of the starter except that wire from the switch to the starter.
              • antichrist
                • Mar 2009
                • 272
                Here's a good troubleshooting process to tell you where the issue is.
                Here's a good video on the topic.
                Just because the connections look good, doesn't mean you don't have bad cables.
                This is 6" from the cable lug on a starter cable from a Land Rover I bought a few years ago.
                Tom Rowe
                62 88 reg
                67 NADA x2
                95 D1 - R380
                95 D90 - R380
                97 D1 - ZF
                • Enigma
                  • 88
                  What maintenance does one do for a starter? What lube do you use and where and how much should I use?
                  • antichrist
                    • Mar 2009
                    • 272
                    Starters are pretty much maintenance free.
                    The best way to take care of them is make sure your battery is charged and your connections and cables are in good shape with no corrosion (I use dielectric grease on all positive connections and Never-Seez on all earth connections, or the reverse for positive earth vehicles. I use AGM batteries so don't use anything on the battery posts, but dielectric grease or the spray stuff wouldn't hurt.
                    Tom Rowe
                    62 88 reg
                    67 NADA x2
                    95 D1 - R380
                    95 D90 - R380
                    97 D1 - ZF
                      I'm thinking along the lines of making sure the mechanism that throws the pinion out to engage the flywheel isn't all gunked up, that the rotor bearings have lubricant (if possible on the old starters--not sure what type of bearings they use), that the brushes aren't knackered, etc.
                      • antichrist
                        • Mar 2009
                        • 272
                        All good things if the starter is out. I was thinking routine maintenance.
                        Tom Rowe
                        62 88 reg
                        67 NADA x2
                        95 D1 - R380
                        95 D90 - R380
                        97 D1 - ZF
                        • timc930
                          • Jul 2013
                          • 117
                          So I've cleaned all the connections, disconnected the battery cable, then moved the end at the switch over to the starter side, touched the battery cable to battery (now direct power to starter) and the starter still drags as if tremendous amount of resistance, but the truck will start and run fine, just takes a bit more. I think at this point I am going to pull the starter and just order one of the high torque Nippondenso starters from British Starters. I think I want to slowly upgrade all the electric components, already installed the Pertronix Dist and Coil. I'll post updates after I get the new starter installed.....
                          tim
                          Tim
                          05 L322 (Daily)
                          95 RRC SWB
                          05 E320 (Wife)
                          • o2batsea
                            • 1199
                            The brushes on the starter motor are likely worn out. Take it to your local armature shop. They can refresh it for cheap. They'll turn the commutator, install brushes, check the bushings, lube it up and throw a coat of paint on it and probably only charge you $50.
                            • triumphtr7guy
                              • Jan 2011
                              • 66
                              good pic Tom, had a Ford Explorer that the positive went under the bell housing and then up again to the starter, failed on me , thought it was the starter, checked some more, opened up the wire, had maybe 2 strands and whole lot of copper oxide.
                              Also on my S III, the connector to the starter was steel! gave the same type of fail, pulled the wire, soldered in a copper connector and all is right with the world
                              Bruce 73 Series III
                              80 TR7 awaiting reinstall of head
