I carry around an old rag, and if I am going to park for very long, get it wet and wrap it around the carburetor at the bowl. This has worked well for me. The only times I remember getting vapor lock since starting to do that is when I forget.
I've gotten the wait time to go away down to a minute or so as well. I've still got a mechanical fuel pump. I remove the fuel line from the carburetor, and direct it into the throat of the carb after removing the hose from the air filter. Then I actuate the fuel pump. If it do this quickly, it doesn't work, but if I pump it slowly, it begins to draw gas. After getting one or two squirts in the carbeurator, I lite it up. Taking advice from a few other people, I also choke it and rev the engine when starting. If it stays lit, the choke comes off, and I'm geared to go.
