Clutch Slave Cylinder Replacement
  • warrenperkinson
    • Jan 2014
    • 78
    My clutch slave cylinder is on the way out and it looks like I will need to replace it.
    This is in a RHD '71 series IIa SWB.
    Are there any tricks to this? It looks to me that other than needing to become a contortionist with tiny double jointed hands, it's just a case of undoing the 2 half inch bolts that hold it in, ripping the old one out and bolting in a new one...
    ...or am I missing something critical here...?
    Given that I'm not a contortionist with tiny double jointed hands, can anyone give my any suggestions as to how I get those two bolts undone?
    Cheers, and thanks for your help,
    Warren.
    '71 Series IIa "Horace"
    88", RHD, 2.25 petrol.
    New Zealand.
  • Jim-ME
    • 1379
    Take your floor out. It makes it much easier.
    Jim
    • warrenperkinson
      • Jan 2014
      • 78
      Damn. I was afraid that was going to be the response...
      New Zealand.
      • Opabob
        • Feb 2012
        • 40
        I decided to replace the hose at the same time and that gave me more trouble than the slave cylinder. Mine had a banjo fitting which helped some, but not sure if that was added on by a previous owner or a standard part. I had to buy new crush washers for the banjo fitting.
        • TedW
          • 887
          I had the banjo fitting on mine but removed it and installed the hose straight in - better fluid movement, in my view.
          Ted
