I'm planning to re-seal both laminated windscreen panels on my '71 S2a. Does anyone have experience doing this who could provide some insight? Of course, if I break anything, I'll be installing new laminated glass too!
QUESTIONS:
Is the same sealant material to be used on both sides of the glass? That is - on the forward-facing side between glass and frame - as well as on the inside of the glass, between the glass and those screw-mounted metal strips? I read somewhere that only RUBBER should be used on the inside - between the metal mounting strips and the glass. RUBBER strips, as in using thin strips of bicycle tube rubber?
I've encountered different products and I'm not sure what's the best to use. Examples: 1) Our host's product # GT106, a 50' role of Glazing Seal (Windscreen Glazing Putty), 2) 3M's Window Ribbon Sealant, and 3) Butyl seal Putty Tape - which seems to be available in various widths and thicknesses. What's the right product to use?
I do plan on removing the windscreen and finishing the job on a bench.
Any suggestions (or warnings) will be appreciated!
QUESTIONS:
