My LR has been sitting for 6+ years without use but I was able to star the car after minor mechanical work and extensive cleaning of the gas tank.
Took the truck for test drive and noticed that the breaks work only after pumping the pedal several times. I bled the lines thru the bleeding ports, first by gravity and then by pumping on the pedal, some air came out but still the truck won't break.
Any advice on the correct way to bleed the air or maybe some other things that need to be check to make the breaks work?.
Thanks,
Neil
Thanks,
Neil
