How are the demister/defroster hoses attached
  • IIA
    • Apr 2010
    • 162
    I'm thinking about replacing the hoses for the defroster / demister on my 1970 IIA. The ones I have now are functional but are cracking. Before I pull them off, though, could someone explain (or post a photo) of how they attach at the bottom to the heater box? Are the just stuck onto a tube at the base, or is there something more complex with other parts that'll need replacing?
    1970 Series IIA
    1964 Series IIA [sold]
  • lumpydog
    • May 2014
    • 383
    Hose clamp. Simple to remove.
    1968 Series IIa
    • TedW
      • 887
      You just push them onto the two upright tubes on the top of the heater box. Clamping them is fine, but you may not need to - I have the same setup (1970) and the originals are just press-on.
      • Jim-ME
        • 1379
        Mine are also just pushed on. They work fine for me without hose clamps.
        Jim
        • IIA
          • Apr 2010
          • 162
          Thanks. That's what I was hoping.
          1970 Series IIA
          • trsheph
            • Sep 2014
            • 14
            mine have a small sheet metal screw through the ends of the tubes into heater outlets
