Hello! I've got a RHD S3 109 FFR. I'd like to sort out the gremlins in the instrument panel. I have the green bible as well as the military operation manual.
Could y'all please help me understand how to troubleshoot the problems (overview below)? Do I need a multimeter? Any other specialized tools?
Thanks!
Here is a summary of what works/doesn't work:
Left Side
Left turn indicator (orange) - the right side lamp (green) comes on when the left turn signal flashes...
Speedometer - works!
Odometer - works!
Tripometer - the reset thingy doesn't reset, it just twists the numbers up
Oil pressure indicator (green) - don't know
High beam indicator (purple) - works!
Cold start indicator (orange) - always on...
Right Side
Right turn signal indicator (green) - works, but for the left flasher. Turn signal stalk is stiff and won't click for the right signal....
Water temp - pegged at the bottom, something not right
Oil temp - seems to work, moves to the little tick mark just under 85C, who knows if the gauge matches reality...
Fuel gauge - doesn't work for the right tank, but does work for the left tank...assume its a sender?
Thanks!
Left Side
Odometer - works!
Right Side
