First post here. I became a Land Rover owner for the first time five days ago.
When I got my Series IIA Landie, it ran pretty well but was rough between idle and about 2000 rpm, particularly under load. It also ran better with the choke pulled out slightly.
First, I cleaned the carb. The carb wasn't very dirty. It's a new Zenith carb that is less than 2 years old. I didn't think that the carb was really the issue, but it didn't require any parts and I figured it couldn't hurt. That didn't change the issue much, if any.
After further research and diagnosis, I determined that the vacuum advance diaphragm was busted. As I was planning on eventually switching to electronic ignition anyway, I ordered a replacement electronic distributor and a new coil that should arrive today.
My question is, how do you properly set the ignition timing if the marks on the flywheel only go to 6° before TDC? I haven't seen the specific instructions for my new distributor, but instructions for electronic conversions I have read say to set timing at something like 30° BTDC at 3,500 RPM (don't pick at these numbers, they are not meant to be specifically correct for a 2.25 engine, they are just for describing my anticipated problem). How have people who have gone electronic set the timing to a spec like this which would need a mark well before 6° BTDC? Did you just start with the distributor set as it was out of the box and tune it by ear or what?
I was thinking about counting ring gear teeth and making my own mark based on that. I saw on another forum that said the 2.25 petrol engines have 98 tooth ring gears, can anyone verify this? I couldn't find another reference for the the number of fly wheel teeth.
Thanks in advance!
Thanks in advance!
