I have a 75 series 3 88" Diesel. I recently had the head off machined... all the pistons replaced, new bushings and lifters. Since the work has been done the car smokes (white) and runs very hot almost overheating. For the overheating I have replaced the water pump, some hoses, sending unit and thermostat.
I have tried to adjust the injector pump a bit by rotating, thought it might be a un-burned fuel, does run smoother but still smokes a lot only at idle no smoke once in motion.
If I remove the thermostat it runs right in the middle or lower but there is no heat coming out of the heater.
Not sure what the problem is or what to do next could use some advise.
Kai
Kai
