I have a Series II engine that is yours for the taking.
Local pickup only - Massachusetts.
This is basically a short block engine. There is no head, oil filler neck or ancillaries.
The block has NOT been broken down. So the pistons, rings, crankshaft, bearings, etc...are all undisturbed and should be fine to run. This was a running motor when removed several years back and has been stored inside since.
