Removing Crankshaft Pulley
  • mpreston14
    • Oct 2015
    • 23
    My Crankshaft pulley is rust-bloomed and needs replacing, the amount of sanding to get it ok isn't worth the time. I have the replacement, but for the life of me cannot get my head around how to actually get the old pulley off. After reviewing the parts catalog, the Starting Dog (hand crank piece) and the large nut appear to be one piece. How is it threaded, reverse or regular?
    I appreciate your help!
    Mike
    Mike
    66 IIA
    07 LR3
    13 RR Sport
  • 64Blue
    • Sep 2007
    • 64
    I have an extra pulley and nut but can't seem to find them... So I am going off a ten year old engine rebuild memory and the fact the dogs on the nut would be tightening to start..... I think it's just a regular thread. I got it off just using an electric impact wrench. Spun right off. But again. Can't remember which thread for sure so tread lightly.....
    • Les Parker
      • May 2006
      • 2020
      Standard thread.
      Les Parker
      • mpreston14
        • Oct 2015
        • 23
        Thanks everyone!
        Mike
        66 IIA
        07 LR3
        13 RR Sport
        • singingcamel
          • 398
          Impact is the only way to go.
          • tmckeon88
            • 142
            There's a trick where if you can brace a breaker bar against the frame, you can "bump" the starter with the ignition off and make the whole engine your impact wrench. Obviously you don't want to actually start the engine.
            Tom
            Tom
            1969 Series IIA 88"
            • 64Blue
              • Sep 2007
              • 64
              Tom
              Yes. I did this with my'04 disco. SUPER exciting. But worked. I'd zip tie the bar so no smashed body parts..... Definitely bad Kung fu.
              • mpreston14
                • Oct 2015
                • 23
                My starter is at the Armature for rebuild, so the impact socket has been ordered as well as an extra retaining clip and starter dog...(cause nothing ever goes right :/ )
                Mike
                66 IIA
                07 LR3
                13 RR Sport
                • mpreston14
                  • Oct 2015
                  • 23
                  Well I finally got the starter dog off! Tried heat, didn't budge. Tried 1000 foot lb torque impact wrench, didn't budge. Bought a slug wrench on eBay for $40 and 4 hits later it spun free! 2 months of off and on efforts to break that &$<€'er and finally done...now to pull the pulley...
                  Mike
                  66 IIA
                  07 LR3
                  13 RR Sport
