Independent wiper question
  • Enigma
    • 88
    I cleaned and regreased both motors a couple of years ago. Lately I noticed the sweep of the blades has changed. The drivers side arc is about 135 degrees while the passenger side is only about 85 degrees.
    Any possible reason for the discrepancy?
    cheers. John
  • singingcamel
    • 398
    Did it do the same thing prior to the rebuild? If not I'd pull it apart and have a look
    cheers. John
    • cedryck
      • Sep 2010
      • 836
      Ha, My wipers are independent and have about the same sweep, but, one responds to a regular motion while the other looks like it is attending a Grateful Dead concert, it just moves slooowly back and forth as if sedated.
      • singingcamel
        • 398
        Maybe you packed to full of grease ,that old grease pretty hard in those old wiper motors ,most of the time you need to clean it all out and regrease them, the main cause of the sloooooooooooow movement.
        • Oscar
          • Dec 2008
          • 51
          That and corrosion on the various shafts and bushings. Just had my two apart and they are doing much better now. The large gear had "100" on it which I assume is the number of degrees of sweep. Don't see how that could change......
          Hannibal...... 1964 SIIA 88" NAS.....
          • cedryck
            • Sep 2010
            • 836
            Can anyone suggest a good link to reworking the independent wiper motors?
              Link to a "how-to", or a link to somebody who rebuilds them?
              • darbsclt
                • Jul 2013
                • 166
                If it's a "how to" you're looking for, THIS is the link I used.
                Between the site... the pictures posted on it... and the links it supplies as reference, you should be all set.
                From experience, be careful of the circlip and spring on the wiper shaft - they are eager to fly across your shop/kitchen.
                • Star27buck
                  • 55
                  Peter Gigliotti rebuilds them in Walpole Mass, 617.645.5703: hornandwiper@gmail.com
                  • Jim-ME
                    • 1379
                    So does Ike Goss @ Pangolin4X4
