Has anyone fabricated a roll cage for an 88. I just bought a 72 my wife will drive occasionally and I want to put a soft top on it, and feel a cage should go on. 😅 I'f someone here has done this, I'd really appreciate some dimensions. Or if someone has a hoop set in the southeast I could buy to pull dimensions from, I'd buy it. Thanks
Dimensions for tubular roll cage/soft top frame
Bryan Deel
1967 109 3 Door, 2.6l, RHD
1972 88 2.25, LHDTags: None -
Hi Bryan, I had a roll bar built at a local fabrication shop that specializes in custom components for boats, bimini tops and tuna towers as well as architectural products. We designed mine to fit inside the hard top or a soft top if I ever acquire one. It's also placed far enough aft to clear a truck cab. I originally thought a pair of diagonal struts would be needed but the double roll bar bolted to the mating piece below seems to be more than adequate. The roll bar serves as a mounting point for a pair of aftermarket inertia seatbelts and also fits a generic Jeep bikini top. I considered designing it to be integral with a soft top hoop set but soon realized that would preclude using the hardtop. I'd be happy to pull some dimensions off this one if you are interested. -
Thanks kb1iaw, I like that it is connected to the frame. I guess I could just pull dimensions inside the hard top. CheersBryan Deel
1972 88 2.25, LHDComment
