I'm a little discouraged today. I got a quote for replacing the rear main on my new 79 series 3 ,88 inch . It was over 2k by someone who is familiar with series. Is this normal maybe not sure need advice , Gareth,Dallas. Thank you
Rear main seal
If the Series 3 is new to you and you don't know how much it's been driven of late prior to your acquisition, you might try some seal softener first. If it's just a little hard from sitting and dripping a bit, some seal softener might just take care of your problem. There are clearly different opinions about these products but I've used them in a 1960 and a 1965 Cadillac (both of which had been sitting for a good while) and seen substantial improvement. I've also heard that synthetic oils have a better performance in weak seals than traditional oils but I have no personal experience with that as both cases I'm referring to were quite a while ago. You need to drive your car several hundred miles before the seal softener can have an effect... Bottom line - $10 worth of seal softener or $50 worth of a synthetic oil change might be worth a try. Hope that helps some. -
I'll be interested to hear how the softener works.
Other thing to consider: Crank case pressure. Sometimes people will mess with the emissions equipment - remove it. Done carelessly, it leaves the crank case with no way to vent or neutralize pressure. Do you have a connected PCV valve?
Other sources of pressure include worn rings, allowing blow-by - what's your compression for each cylinder?1968 Series IIa
1997 Defender SW (Original Owner - Sold)Comment
If this is your first Series truck, your idea of a major leak might be grossly different than someone who has owned one for a while.
Just about all of them leak.
How much oil are you losing? Why don't you post a picture of the driveway after you have driven the truck and parked it for several hours.1969 IIA - Tan
1969 IIA - BlueComment
Zimbos - curious to see where this ended up. What seal softener did you use? I've seen Bar's rear main seal additive which seems to be based on petroleum distillates and seems to work by softening the seal. I've also seen AT-205, which is more of a plasticizer and seems to work by restoring the flexibility to the seal. Neither will work for a damaged deal - they do not plug holes, rather they change the characteristics of the seal.1968 Series IIa
$2K is about right, to remove engine and do per O2Batsea posted factory instructions.
Other option is do go the route I did and pay two different shops $900 and $500 respectively; they both said they could replace seal "no problemo amigo" without removing engine from the truck. Then ultimately I paid $1,800 to have it done right in the US by removing engine from the truck.The Toltec Coffee fleet....
56 Series I 86: a whole new type of rover hell....Comment
