Hi, in the process of replacing engine harness with one from Brit wiring. Previous owners nest got torn out and in the process of doing it right. I am trying to figure out the engine harness routing.
Theis is is for a 64 2a with alternator conversion....left hand drive.
Does the harness route from the fire wall, attach to the green wires then to the oil pressure switch, then around the front of the engine to the alternator, washer bottle and carb warmer ( if you have one)? Or do it firate route along the back of the firewall on the opposite side ( left side) to alternator. I don't think I am asking this clearly, so perhaps a pict if someone has one? Many many thanks
j
j
