I purchased a new 3 prong flasher unit from Rovers North and have wired it correctly but when I use the turn signal the warning light in the signal stalk doesn't flash. I've taken apart the turn signal, all the wiring is correct and when I run 12 volts through the wire to the warning light it does actually work. I tested the voltage coming off the terminals of the flasher, on the "L" and I get 12 volts on the "P" terminal there is barely any voltage. The "L" Terminal is for the turn signals and the "P" terminal is for the warning light. Does anyone have any experience with this? I think it's probably a defective flasher........
Turn Signal Warning Lamp
Is the flasher unit grounded? As noted above, please ensure all the ground and power leads are "good".Les Parker
I would consider dirty connections first. I've had a number of times where I can get continuity with a volt meter but the circuit didn't have enough current to light a bulb. The best thing I've found is to use a rotary tool with a stainless steel wire brush on the terminals. Also a bit of dielectric grease on the contacts helps prevent future corrosion.Comment
The flasher unit is behind the gauge panel, mounted to the bulkhead with a self tapping or machine screw. Usually it is in the center part of the dash, hiding behind the rats nest of wiring.Les Parker
Yes it was there! Not kidding
Just got flashers back on line. New 3 prong flasher. First installed, lights has a flicker. Change wire location on flasher. The 2 wires on each side of each other. Works great now
1967 Land Rover 109
1966 Land Rover 109
Joshua TylerComment
