Wiper Motor Electrical Issues
  • RoverKid_1972
    • Mar 2015
    • 39
    Hey all! I'm having trouble with the wiring in my wiper motor and switch. Attached are pictures of the setup. I am currently running power through the solid green wire (main power) into the switch and to the wiper motor. I am NOT running power to any other tabs on the switch nor am I getting power to any of the tabs on the motor itself (except the main power tab connected to the green wire). If you guys can see any problems with my wiring, please let me know. Otherwise I think I may need to purchase a new switch.
ID:	173722Click image for larger version
ID:	173723Click image for larger version
ID:	173724Click image for larger version
ID:	173725Click image for larger version
    Side note: If you know of a tool that could unscrew the ring holding down the switch, I need to purchase one.
    Thanks again.
    1972 Series III Frankenstein
  • cnfowler
    • Mar 2015
    • 150
    Can't help you with the wiring, but to remove that ring just place a small flat blade screwdriver in one of the slots and tap the end with whatever you want in the direction you're trying to go - to the left to loosen and to the right to tighten.
    Colin
    • ernest.irw
      • Mar 2016
      • 29
      Hi Roverkid I'am not sure about the blue green wire that is connected to your wiper switch, mine is black-green, brown-green, red-green and green-green. What I know that the green box behind the switch (labeled Lucas) is for wiper washer,activate if the button is pressed. The other pin are for full speed and half speed. I think the green-green and the black green wire is correct (similar to mine) but be advised that the green box is prone to loose wire, there is a small wire inside the green box. Mine also have brown-green and red-green wire but it could be the other way around depending the position of the switch, that is for half or full speed. But all these color only applies for original wire spec from factory, if it have been be replaced by different wire, it is hard to tell. There is also a big ground wire just behind the wiper motor, it is must be connected to the bulkhead in order to work properly.
      • bobzinak
        • Apr 2009
        • 91
        my advice, take the switch apart. You can carefully bend the tabs on the back of the switch and disassemble it. nothing hard about it. just by examining the inner switch contact points you can easily figure out what contacts are energized. I once had a new switch that had the rotating contact plate inserted backwards, who knew..
        If your going to become a long term rover owner these are the things you will often encounter..it's not just a method of transportation, it's also a hobby (obsession)
        that said it will make you a lot of friends you never knew you had..people here will help you.. ROVE ON bobzinak..
        • RoverKid_1972
          • Mar 2015
          • 39
          Thanks to everyone for the replies. I've ordered a new switch that now runs power to the motor. But now I have a new issue: the motor only runs one speed and blows the fuse every time. Anyone experience this issue?
          • clearcut
            • Jul 2014
            • 233
            [ATTACH=CONFIG]11669[/ATTACH][ATTACH=CONFIG]11670[/ATTACH][ATTACH=CONFIG]11671[/ATTACH][ATTACH=CONFIG]11672[/ATTACH][ATTACH=CONFIG]11673[/ATTACH]
            [ATTACH=CONFIG]11674[/ATTACH]
            Thanks again.
            Call Moss Motors. They should have the tool
            I have one and it works great
            VIEW LARGER
            Bezel Remover Tool Set
            $33.99
            PART # APPLICATION
            384-960
            In Stock
            Josh T
            1967 Land Rover 109
            1966 Land Rover 109
            Joshua Tyler
