Hello everyone -
Do any of you out there have any idea how thick the high gear thrust washer (#90217488) is supposed to be?
The parts book, nor the manual indicate how thick it is supposed to be and doesn't offer various sizes like it does for shims and spacers. If the actually do I can't seem to find it.
The problem is that end float is supposed to be between .006 & .008 and it isn't; right now it's right at .016.
The manual says:
"Adjustment of the high gear wheel end float is made by reducing the thickness of the thrust washer, or fitting a new thrust washer, as required. If fitting a new thrust washer fails to reduce the end float to the required limits, replace the shaft and/or the gear."
If I knew how thick a new thrust washer is it would help me figure out if I need to purchase a new one or not.
I have found no indication that this thrust washer can be purchased in various sizes or if shims are available
Thoughts? Advice?
The manual says:
Thoughts? Advice?
