Strange metal strip
Tags: None
That's what I was thinking when I saw the photos, but those certainly aren't "small metal strips" as described in the OP.
Could he be referring to the metal strips that came INSIDE the original door seal weatherstrip (and are left behind when the rubber part rots away from around the metal strip) ??--Mark
It does look a bit too bulky. These are just strips, with a rolled bead along top, that appear to have been riveted behind the door seal. They aren't the metal strips inside the door seal though. Those came off with the door seal. I could always get a sheet metal shop in town to just roll the edge on some galv and then I could rivet it behind there. Just curious because I can't find what they actually are. :-/Comment
What you're describing isn't a "small" metal strip. It runs the entire length of the door opening. After looking at mine, it definitely looks to be the above listed parts. Here's another picture from another parts book. Land Rover calls this part the sill channel. I can't find the part numbers for the rear doors.
ColinComment
Here's pictures of mine. Without the rust it is a bit easier to see. The top part of the channel goes under the edge of the seat box. You can see in the diagram above that three holes in the channel align with the three in the seat box and the other two align with the two in the floor panel.
ColinComment
It looks like these ones were replaced in the past them, because they are most definitely not welded along them. How do I find the thread where you made new ones?Comment
