Turn Signal Flasher
  • timc930
    • Jul 2013
    • 117
    Turn Signal Flasher
    1963 Series IIa: Turn Signals quit working.I have been able to trace the wires from the Turn Signal "Actuator" on the steering column to the lights, but I am unable to trace the wires to the power source and or fuse block. I removed the Dr side Fender to inspect the Clutch Master Cylinder, and in doing so, I disconnected the wires to the lights. I reconnected. All lights work fine except turn signals front and rear.
    Tim
    63 IIA 88" (Beach with the dogs)
    05 L322 (Daily)
    95 RRC SWB
    05 E320 (Wife)
    86 930 (Rush on boost, 400HP and climbing....)
    A few boring BMW's for the kids (E30, E36, E46, E53)
    1) NONE of the turn signals work at all, or just the left side?
    2) What do you mean "been able to trace the wires"? Just identified/located the wires, or put a meter on them looking for 12v?
    • timc930
      • Jul 2013
      • 117
      1) None of the turn signals work, all other lights (headlights, parking lights, brake lights) work.
      2)Identified/located.
      Tim
      05 L322 (Daily)
      95 RRC SWB
      05 E320 (Wife)
      • cedryck
        • Sep 2010
        • 836
        Grounds, check for appropriate grounding.
          That'd be my first thing to check also, especially where lots of lights ground inside the top of the radiator support panel (at least on the SIII).
          I'd also have a look at the lower right corner of the wiring diagram for the SIIA negative earth electrical system (linked on the Bottom of the page on the RN online catalog under SI SII/A SIII -> ELECRTIC SYSTEM). This will show you the typical electrical paths for the turn signal system, probably for a positive earth as well.
          • timc930
            • Jul 2013
            • 117
            Agreed and understood.
            IIRC, turn signals worked fine before I R&R'd Dr Side Fender and Trans to first inspect the clutch master cylinder and then replace clutch. I reconnected all the wires, correctly up at the corner of the radiator when I reinstalled the fender, so I know that's not the problem. But, as you guys are saying, I do need to recheck all the grounds, problem is, I just don't remember disconnecting any grounds when I R&R'd fender and trans.
            The grounds for the side marker lights and turn signals connect to the same ground at the radiator, which "appears" to go back towards the bulkhead, and the side marker (parking) lights work fine, which tells me the ground is fine, since they both share the same ground.
            I R&R'd the dash panel with speedo, and located what appears to be the flasher unit, as well as locating a bunch of grounds, which I checked. Maybe the turn signals quit before I replaced the clutch and I just didn't notice, and it could be the flasher unit.
            Again, From what I can tell, the front parking/marker and turn signal lights share the same ground up front, and the marker lights work fine, so that tells me the grounds up front are good?????
            Tim
            05 L322 (Daily)
            95 RRC SWB
            05 E320 (Wife)
              If you disconnected the wires when you removed the fender, then you disconnected power wires TO the light AND ground wires FROM the light (each lamp assembly has 2 wires, one that supplies power and one that returns it to the battery through a ground path on negative earth vehicles. Power flows the other direction on positive earth vehicles, but the concept is the same).
              Also, "connected" doesn't necessarily mean there's a good ELECTRICAL path between one wire and the next, especially on ancient contacts, where oxidation can prevent the two connectors from ever making any real metal-to-metal contact with each other.
              • timc930
                • Jul 2013
                • 117
                Sorry, I was not clear. When I stated that I did not remember disconnecting any grounds when I R&R'd fender and trans, I mean't in addition to the grounds at the fender/radiator corner. Those I have cleaned and connected several times to ensure that I have good contact.
                I'll double check those connections again.
                Tim
                05 L322 (Daily)
                95 RRC SWB
                05 E320 (Wife)
                • cedryck
                  • Sep 2010
                  • 836
                  Check everything you disconnected for continuity, my experience with disconnecting bullets has left me in pain, they connect well, but don't come apart will, they often break,
                  • timc930
                    • Jul 2013
                    • 117
                    Thanks all, it was the flasher unit/relay itself.
                    Tim
                    05 L322 (Daily)
                    95 RRC SWB
                    05 E320 (Wife)
