How to remove and replace the front Chassis Bushing Need Help
  • clearcut
    • Jul 2014
    • 233
    Well, we are onto the front end work of my 1967 Tan NADA. First thing was broken spring! Your view on a cause?
    Also, need help or tricks on how to remove the the large chassis bushing and replace with a new. Is there tread already on this issue?
    thanks
    josh
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
  • cedryck
    • Sep 2010
    • 836
    Originally posted by clearcut
    [ATTACH=CONFIG]12037[/ATTACH][ATTACH=CONFIG]12038[/ATTACH]
    thanks
    josh
    Usual reason for breaking, age and or fatigue. The rust will contribute to that as well. Possible over stressed. Not unusual, I have seen them broken in half.
    • parrie
      • Jun 2012
      • 217
      thanks
      josh
      Best guess on the spring breakage would be age. Several different ways to remove the bushing depending on what you have for tools. IMO easiest way is to remove the inner sleeve and rubber via a hole saw or beat them out with hammer. Once these are removed you should be able to insert a sawzall (reciprocating saw) blade to cut through the outer sleeve...work slowly to avoid cutting into the frame. Once the sleeve is cut you should be able to use a hammer & chisel to remove. Over-all the removal is a real PITA. For the install...make sure the hole for the bushing is cleaned up nice & the bushing itself is clean & w/o burrs. Find a socket the same OD as the bushing and use a hammer to drive in the bush. Do not beat on the inner sleeve or the rubber, only the outer sleeve. I'm sure there are more than several threads on this subject. Good Luck!
      • clearcut
        • Jul 2014
        • 233
        frame bushing removal.
        Well we got one out. Had to drill out the center. Bolt would not move. Most interesting was that prior owner had cut a bushing in half. Pushed 1/2 of a bushing in from each side. I assume they did not have a frame bushing.
        josh
        1967 Land Rover 109
        1966 Land Rover 109
        Joshua Tyler
        • REDrum
          • Nov 2011
          • 175
          There is a good YT video on how to remove frame bushes
          The Toltec Coffee fleet....
          96 FZJ80: 3XL, lifted, and shaved
          94 FZJ 80: our Costa Rican coffee and surf mobile
          70 Series IIA 88: After 18 months of wrenching, its alive and legal to drive!
          70 Series IIA 88: in US on H-1B visa
          56 Series I 86: a whole new type of rover hell....
          • cedryck
            • Sep 2010
            • 836
            Google removing frame bushings. There are some good ideas there,
            • cnfowler
              • Mar 2015
              • 150
              Here's the homemade tool he was using.
              Colin
