Layshaft castle nut
  • DGG
    • 304
    Layshaft castle nut
    I'm finally putting together my 109 transmission after rebuilding all the components. I was putting the layshaft castle nut on today, and I'm getting some resistance from the first few threads. The nut threads seem fine, but the threads on the end of the layshaft are not perfect. I thought about tightening it up any way and just trying to get past the first few threads, but stopped thinking I would mess up the nut, or the layshaft. Should I try to clean up the threads on the end of the layshaft? If so, what are the specifications of the threaded end of the layshaft, so I can get the proper tool. This is a pre-suffix transmission, but I think the layshafts are all the same throughout production from Series II to Series III.
    Thanks
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  • I Leak Oil
    • 1796
    Thread file.
    • DGG
      • 304
      Like this:
      Doug
      61 Series II 109 SW
      95 RR County LWB
      06 Range Rover
      98 Discovery LE
      • clearcut
        • Jul 2014
        • 233
        Is there a file? Can not open this one
        Thanks
        1967 Land Rover 109
        1966 Land Rover 109
        Joshua Tyler
        • DGG
          • 304
          I'll try to get a picture.
          Doug
          61 Series II 109 SW
          95 RR County LWB
          06 Range Rover
          98 Discovery LE
          • DGG
            • 304
Name:	lang tools.png
            Doug
            61 Series II 109 SW
            95 RR County LWB
            06 Range Rover
            98 Discovery LE
            • DGG
              • 304
              Just need to know what size. Is it British Standard? If so, I probably won't find anything.
              Doug
              61 Series II 109 SW
              95 RR County LWB
              06 Range Rover
              98 Discovery LE
              • I Leak Oil
                • 1796
                They make small triangular shaped files meant for cleaning up threads.
                • DGG
                  • 304
                  Thanks. That's probably what I'll do since I can't find the specs on the layshaft threads.
                  Doug
                  61 Series II 109 SW
                  95 RR County LWB
                  06 Range Rover
                  98 Discovery LE
                  • cedryck
                    • Sep 2010
                    • 836
                    If you have an assortment of "taps" and "die", you can carefully select on that might fit and see if it "carries" onto the threads. A small file can clean up the large thread enough to accept the nut. Just be careful and work slowly.
