Hey guys,
So my alternator is not charging (dash light comes on) and no voltage increase across battery when engine is running and/or rev'ed. I have checked the impedance from the alternator to positive battery terminal/cable. I am getting about 70 Ohms, but this should be 0 Ohms. Or at least the way I read the schematic, the alternator goes directly to the starter solenoid which has the positive battery connection on the same terminal. Before I go further into the alternator wiring to the solenoid, I wanted to jump the alternator directly to the battery where I know I will get 0 Ohms. I am pretty sure they alternator is toast, but at least I can confirm that. Any issues with doing this that I am not aware of?
If I do find the alternator is bad, then (based on the 70 Ohms I found), I will need to replace the alternator and rewire it to the solenoid and battery to kill this impedance buildup (unless I find connector corrosion I can remove).
Cheers!
Cheers!
