Problem with anti-rock grills over headlamps
  • IIA
    • Apr 2010
    • 162
    My 1970 IIA 88" has protective grills over the headlamps and directional signals on the wings. They're riveted on. Is that standard? The problem is that I can't see any way to change the headlamp bulbs without drilling out the rivets. Before I do that, any other ideas?
    1970 Series IIA
    1964 Series IIA [sold]
  • TedW
    • 887
    I have the same year, same setup, but used stainless screws. I don't know why anyone would rivet them on....................
    • ricker
      • Dec 2011
      • 17
      I used small stainless steel bolts with a rubber washer between the cage and the fender.
      Regards,
      David
      • cedryck
        • Sep 2010
        • 836
        You will need to drill rivets and install new ones after tending to your bulb.
        • Les Parker
          • May 2006
          • 2020
          Maybe the reason for the rivets is an anti-theft preventive action?
          Les Parker
          • IIA
            • Apr 2010
            • 162
            I suppose that's possible, but considering that only the passenger door has a lock, it would be a bit pointless. Someone could just steal the whole truck and take their time with it. I guess I'll be drilling this weekend.
            Thanks for the comments.
            1970 Series IIA
