Background:
So I have a 76 Series 3 RHD 88. I picked it up about 4 years ago. Banged around town with it and decided to do some work on it. It is meant to be a driver and not a restoration...I would have to replace everything on it.
I drove it all through the gears and in 4wd with no issues. Parked it and took the tub off and fixed where there was some rust on the frame.
Got everything back together and ran into a transmission issue.
The PROBLEM:
It will go into gear (via the lever) but will not engage forward gears or reverse when I let out the clutch. I just hear a light whirring/knocking sound. When I put it in 4wd it will go into all forward and reverse gears. Strange...it seems like something is stuck in place inside the box.
I took the tunnel off and the seat panel. The lever is moving what it should be moving as far as the "fingers on the top of the trans" are concerned.
I opened up the top access panels on the gearbox and the transfer case. Fluid was low but the gears were at least wet and there was no sign of wear on the gears or metal shavings anywhere.
Put fluid in and still had the problem.
Thoughts would be appreciated.
Thank you in advance.
-Andy
The PROBLEM:
-Andy
