VDO fuel gauge compatability 1961 109 Station Wagon
  • DGG
    • 304
    I'm trying to install a VDO fuel level gauge. I have this sender: http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
    It's not working. I believe I have everything hooked up properly but when I turn on the key the fuel gauge pegs beyond full. I think I have about 8 gallons of gas in the tank. Not sure if the gauge and the sender are compatible. The gauge has an ohm range of 10-180ohms. If I disconnect the sender completely, I still get a pegged gauge. If I hook up directly from the battery positive terminal to the gauge, I get a pegged gauge. Tested the gauge as per VDO testing procedures, and the gauge is good. Not sure what I'm missing.
    Thanks,
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  • mearstrae
    • Oct 2011
    • 592
    Sounds like you have the "Hot" (positive) wire going straight to the gauge and not going to the sending unit. The positive has to go to the sending unit, and then back to the gauge, so it shows the measured resistance of the sending unit. Take out the sending unit and work by hand, it should make the gauge work, if it's wired correctly.
    • DGG
      • 304
      Did some testing. Bad sender.
      Doug
      61 Series II 109 SW
      95 RR County LWB
      06 Range Rover
      98 Discovery LE
