Testing Fuel Gauge
  • IIA
    • Apr 2010
    • 161
    Testing Fuel Gauge
    My fuel gauge has been acting funny - reading full when full but empty when there's still fuel in it. So, after checking the sender and the voltage stabilizer, I tested the gauge today. The results were off so I want to make sure my test was reliable before I order a new one. Does this sound right:
    I removed the gauge and connected the terminal nearest the F side to the positive terminal of a reliable 10v power source. I connected the E terminal to one side of an adjustable resistor (to simulate the sender) and the other side of the resistor to the ground of the power source. I ran 10v through the gauge at various resistances from 0 to 260. I got those numbers from a chart in another post. Below are the results I got. All the numbers are rough. I estimated what I think the gauge reading should have been on the percentages in the chart and a 12gal tank.
    Ohms Gauge Should Be
    260 Below E E
    207 E ~1/4
    135 ~1/8 1/2
    72 ~3/8 3/4
    42 ~5/8 7/8
    10 F+ F
    0 F+
    So, assuming my test setup was OK, the next question is whether the gauge can be fixed (it's a Smith - probably original).
    1970 Series IIA
    1964 Series IIA [sold]
  • lumpydog
    • May 2014
    • 383
    Mark!
    1968 Series IIa
    • mearstrae
      • Oct 2011
      • 592
      Did you check the sending unit for OHMs? Or make sure the float itself actually, floats in a bucket of water? It may well be the sending unit that's at fault.
        Originally posted by lumpydog
        Mark!
        I only have a ohms vs. temp reading for the temp gauge, I think.
        Since the variable resistance of the sender is linear, if you know the ohm range of the fuel sender, you can just plot this on a graph (or just do the simple math) and figure out how many ohms= 1/4, 1/2, 3/4, etc. on the gauge.
          Oh...Make sure the + and ground wires are on the correct terminals on the sender. Reversing them will give you wonky readings. If you only have 1 wire/terminal on your sender, make sure the sender is properly bonded to the tank and/or body/chassis and that the tank is properly grounded to the chassis
          • lumpydog
            • May 2014
            • 383
            Found it - see Mark's reply here.
            This was the first (of many) time that Mark bailed me out where I got stuck.
            1968 Series IIa
            • IIA
              • Apr 2010
              • 161
              Thanks. I've seen Mark's post and tried all the other suggestions. I think the gauge is the only place the problem could be.
              1970 Series IIA
                Huh...I really don't remember making that graph, though it seems like something I'd do if I had a brand new sender in-hand (like I did when I installed my long-range aluminum fuel tank a few years ago).
